Automatically add dimensions feature request
PLEASE please please can we have an automatic dimension option. For example, as you are drawing walls, it adds the dimension lines automatically. It would b3 good to be able to switch auto-dimensions on an off, also adjust the style and also edit then once done.
Also a feature to do the drawing and then add all dimensions automatically to the drawing with one click. There could be 2 levels, high - adds dimensions to almost everything, and low - adds dimensions to limited number of things.
I find adding dimensions to my drawings takes a lot of time and having an option to add them automatically to walls and other blocks would save me so much time.
Thank you!
