To undo, use the shortcut ctrl + z (command + z if you're using a Mac) on your keyboard ๐คAlternatively, you can use the Edit Menu in Rayon:Master all Rayon shortcuts here: https://docs.rayon.design/documentation/rayons-basics/shortcutshttps://docs.rayon.design/documentation/rayons-basics/shortcuts
